flat
first flat on 2012 le, 45k, called firestone & they rebuild pressure monitor every time u take a tire off. Manuel says u just have to reset low press warning. Wondering if I really need to do what firestone store says. Firestone affininty touring.
Ask them specifically what they call a build kit.
On flat repairs a tire store may replace the tire stem, but the pressure monitor has a replaceable seal. It is reasonable to replace the monitor seal which comes in a kit. They also might replace the battery. |
will the pressure monitor still work if I don't replace the seal, I'll replace tires in a yr..
The monitor will work.
Replacing the seal is insurance against air leaking. |
