grease while replacing tie rod boots?
When I replace the boots, I usually add some ball joint chassis grease to the inner ball joint. Should I also
turn the steering wheel completely right and add grease to as many of the rack splines/teeth that i can reach? note these pics are not mine, just pics I found on internet to illustrate: https://imgur.com/a/iAxi78S Also, can I use standard worm roller clamp for the large end? |
Year of car?
Pic's note showing. |
pics take time to load.
2003 and 2007 |
Use molybdenum disulfide lithium grease.
As to clamps a screw type is OK. Try to find one whose width fits into the groove/track of the boot. |
(Post 104220)
Ball joint should be sealed.
