Sponsored by:
Sponsored by:
grease while replacing tie rod boots?
Old 03-08-2021, 11:24 AM
paulmars's Avatar
Default grease while replacing tie rod boots?
When I replace the boots, I usually add some ball joint chassis grease to the inner ball joint. Should I also
turn the steering wheel completely right and add grease to as many of the rack splines/teeth that i can reach?
note these pics are not mine, just pics I found on internet to illustrate: https://imgur.com/a/iAxi78S
Also, can I use standard worm roller clamp for the large end?
Old 03-08-2021, 09:30 PM
Year of car?
Pic's note showing.
Old 03-09-2021, 09:00 AM
paulmars's Avatar
pics take time to load.
2003 and 2007
Old 03-09-2021, 11:15 AM
Use molybdenum disulfide lithium grease.
As to clamps a screw type is OK. Try to find one whose width fits into the groove/track of the boot.
Old 03-09-2021, 11:43 AM
paulmars's Avatar
on the inner ball joint too? if yes why?
Old 03-09-2021, 07:01 PM
Ball joint should be sealed.
MMA1991
11-26-2016 02:34 PM
rajp
11-12-2012 08:55 PM
pctechwright
10-25-2011 07:14 PM
Adam83
03-09-2009 08:51 PM
Quick Reply: grease while replacing tie rod boots?
