High Idle when COLD
Have a 1990 2.5 V6, when cold the high idle is about 1700rpm. Is this normal????
Another question is; it shifts hard into reverse or drive when cold...otherwise it shifts OK....normal??? Thanks Dan |
RE: High Idle when COLD
Have a 1990 2.5 V6, when cold the high idle is about 1700rpm. Is this normal???? I'm sure that someone else will chime in here with more certainty. Another question is; it shifts hard into reverse or drive when cold...otherwise it shifts OK....normal??? |
My wife's 02 Camry V6 starts up at about the same rpm. My 07 Infinity G35 6MT at 2000 RPM. Her Camry even jolts as it shifts to D then let go, which is caused by the high RPM. Hope this eases your concern.
