Intake manifold removal
How hard is it to remove the intake manifold on a 4 cyl 93 Camry? From the looks of it the motor is slanted backwards so it looks like it will be hard to get at the bolts. Can the motor be tilted forward to get at the intake bolts better? One set of instructions I read says to drain the coolant first, is this really needed? any help is great.
Tilting forward may be a lot of work. Unbolting the mounts, might have to remove the axles, exhaust system issues. Might ask at the Toyotanation website.
The IAC valve on the throttle body has a coolant line running to it. Look for smaller diameter coolant lines running to the area of the throttle body. |
ahh ok that makes sense.
