Intake manifold removal
Old Oct 25, 2010 | 08:54 PM
Sprout's Avatar
Default Intake manifold removal
How hard is it to remove the intake manifold on a 4 cyl 93 Camry? From the looks of it the motor is slanted backwards so it looks like it will be hard to get at the bolts. Can the motor be tilted forward to get at the intake bolts better? One set of instructions I read says to drain the coolant first, is this really needed? any help is great.
Old Oct 26, 2010 | 12:04 PM
Tilting forward may be a lot of work. Unbolting the mounts, might have to remove the axles, exhaust system issues. Might ask at the Toyotanation website.
The IAC valve on the throttle body has a coolant line running to it. Look for smaller diameter coolant lines running to the area of the throttle body.
Old Oct 27, 2010 | 06:44 AM
Sprout's Avatar
ahh ok that makes sense.
brianjrealtor
May 30, 2023 04:03 AM
coyotemdcn
Jul 11, 2014 11:40 AM
jimhey
Nov 28, 2011 07:05 PM
Marvel
Jul 13, 2009 10:55 AM
EZ Boy
Feb 29, 2008 04:48 AM
