oil filter
I need to change my oil filter on my 07 Camry. I am used to the twist off type.
I bought a "tool" at autozone that slips over the oil filter housing so that you can turn it. It broke as soon as I put the ratchet on it. Is there a heavy duty tool that I can purchase to remove the filter housing? |
RE: oil filter
I have never found the type that broke for you to ever work. Take it back and get your money back. I have always used the steel band clamp type that gets tighter the more you apply torque. You can get them to be used with a rachet or they come with a handle. Another I have also used with successis one with a nylon band that is attached to a steel square tube which uses a rachet wrench. It also gets tighter the more you turn it. Depending on access should determine which you use.
RE: oil filter
wow you broke that...dang that filter is on tight. you will want to try other things.
if all fails you need to bing it into a shop. a few members includinig myself have had filter issues before, and we ended up stabbing the filter with a screw driver and forcing it off. not good for a new car under warranty tho. |
RE: oil filter
The oil filter housing is cast steel. You can not put a screw driver thru it. The filter is inside the housing. I am having trouble getting the housing to screw off.
RE: oil filter
1 Attachment(s)
Let me get this straight, you're telling me i cannot do this? Attachment 4647
or perhaps you're talking about something i am totally unfamiliar with. |
RE: oil filter
Yes. The 07 Camry does not use the can filter. The replacement filter is just the paper part of the typical can filter. There is a steel housing that the filter goes in. You do not replace the steel housing. It is a permenant part of the engine, and you can not put a screw driver thru it. To change the filter you must unscrew the housing. Hence lies the problem. You must have to have a special tool that will fit it. I can not find a quality tool.
RE: oil filter
ORIGINAL: bosulli You must have to have a special tool that will fit it. I can not find a quality tool. |
RE: oil filter
wow the 2gr uses an interesting filter design. good luck.
