Picture Help
1 Attachment(s)
Can some one please tell me what the attached picture is ? Also why would this cause engine to vibrate at idle when you cut the AC on ? I have a 2008 Camry LE. Thanks Mason
that is the exhaust shield
any vibration first check all the engine mounts |
I will check them. It only does it at idle and when AC is on does not do it any other time werid.
when was it last serviced .. plugs leads ?
idle speed control sensor could be faulty is the engine light on ? |
Serviced at 5000 miles
no lights on |
no engine light is a good thing
what is its rpm idle ling without AC ? and rpm with AC if it is an automatic i would be thinking TPS might need a clean of the throttle body |
I would say about 800 and it drops at least 50 to a 100 when you cut it on.
That shield looks sturdy on its place. See if head bolts are tight.
