Radiator Fan doesnt run
Radiator Fan doesnt run.
Replaced the Radiator (Napa) upper and lower Rad Hoses (Napa) Thermostat (Napa) Rad Coolant Switch (Napa) Rad Temp Switch is new Napa part. (Made in Spain) had Napa replace switch (Made in Italy) When Dash Temp gauge is at 3/4 hot Drivers side Fan doesnt run nor pass side fan. when A/C on Both fans run (each show @6.5 volts) When connector removed from Rad Temp switch, Dr side Fan runs. When that connector reinstalled, Fan stops running. With Rad Cap off, Water Flow can be seen after engine get warm. What is the Problem? |
What year and engine type (V6 or 4 cylinder)?
Rad fan doesnt run
Rad fan doesnt run
94 Camry 4 cyl 2.2 |
