Radiator Fan doesnt run
Old Mar 31, 2010 | 12:01 AM
EarlT's Avatar
Default Radiator Fan doesnt run
Radiator Fan doesnt run.
Replaced the Radiator (Napa)
upper and lower Rad Hoses (Napa)
Thermostat (Napa)
Rad Coolant Switch (Napa)
Rad Temp Switch is new Napa part.
(Made in Spain)
had Napa replace switch
(Made in Italy)
When Dash Temp gauge is at 3/4 hot
Drivers side Fan doesnt run
nor pass side fan.
when A/C on
Both fans run
(each show @6.5 volts)
When connector removed from Rad Temp switch,
Dr side Fan runs.
When that connector reinstalled,
Fan stops running.
With Rad Cap off,
Water Flow can be seen
after engine get warm.
What is the Problem?
Old Mar 31, 2010 | 12:19 AM
What year and engine type (V6 or 4 cylinder)?
Old Mar 31, 2010 | 10:50 AM
EarlT's Avatar
Default Rad fan doesnt run
Rad fan doesnt run
94 Camry
4 cyl 2.2
newbie888
Aug 30, 2011 11:56 AM
darimura
May 18, 2011 09:09 PM
pewterpower
May 2, 2009 10:22 PM
python
Apr 5, 2008 08:10 AM
98camryblue
Nov 25, 2007 06:40 PM
