spun bearing
crank change in car ?
spun bearing crank change in car ?
does it make sense even to you? lemmi guess. it's either main bearings or connecting rod bearings, if it's on "crank", which I am assuming is crankshaft. I have done connecting rod bearings on a car twice. You drop down oil pan, remove engine head, lower pistons and undo connecting rods - then swap out bearings. same time, piston rings can be replaced. as of main bearings - maybe. If you can get to them. |
