steering
I just aquired a 1995 camry le, 4cyl and there is something wrong with the Steering. I am fairly certain that its the Power Steering Pump because the steering is jerky and the belt squeals when i turn it all the way.
i know another person with a 1994 camry xle and she has gone through 2 PSPs and i am wondering if this is a well established issue or if its a fluke. If it is well established has Toyota or an after market company manufactures one that doesnt suck. |
RE: steering
I wouldn't look for a pump problem first. Check your belt tension. Then your steering rack. It almost sounds like there is a binding in the steering somewhere.Might even be a ball joint. I just replaced a perfectly good original P/S pump on my carbecause of a leak in the shaft seal. Ijust didn't want to messwith the seal. The re-built replacement came with a lifetime warranty. The only way to check a P/S pump is to do a pressure check.
RE: steering
Just throwing this out there. I believe Toyota did a recall on 1995 Camry for steering issues:
THE STEERING WHEEL SET NUT MAY NOT HAVE BEEN SUFFICIENTLY TIGHTENED CAUSING STEERING VIBRATION AND LOOSENESS http://www.automotive.com/1995/12/to...lls/index.html |
