steering
Old May 14, 2007 | 01:51 PM
curry's Avatar
Default steering
I just aquired a 1995 camry le, 4cyl and there is something wrong with the Steering. I am fairly certain that its the Power Steering Pump because the steering is jerky and the belt squeals when i turn it all the way.
i know another person with a 1994 camry xle and she has gone through 2 PSPs and i am wondering if this is a well established issue or if its a fluke. If it is well established has Toyota or an after market company manufactures one that doesnt suck.
Old May 16, 2007 | 09:48 AM
pedro's Avatar
Default RE: steering
I wouldn't look for a pump problem first. Check your belt tension. Then your steering rack. It almost sounds like there is a binding in the steering somewhere.Might even be a ball joint. I just replaced a perfectly good original P/S pump on my carbecause of a leak in the shaft seal. Ijust didn't want to messwith the seal. The re-built replacement came with a lifetime warranty. The only way to check a P/S pump is to do a pressure check.
Old May 22, 2007 | 11:14 PM
gslrider's Avatar
Just throwing this out there. I believe Toyota did a recall on 1995 Camry for steering issues:
THE STEERING WHEEL SET NUT MAY NOT HAVE BEEN SUFFICIENTLY TIGHTENED CAUSING STEERING VIBRATION AND LOOSENESS
http://www.automotive.com/1995/12/to...lls/index.html
RUCKUS
Oct 10, 2006 03:49 PM
stu102
Apr 17, 2006 03:42 AM
michael
Sep 23, 2005 04:36 PM
trdcamrygracia
Aug 15, 2005 09:37 PM
Dan_Lemur
Jul 6, 2005 02:20 AM
