boricua |
07-15-2012 09:25 PM |
a 2.5L or 2.4L engine doesn't have a timing belt , they have timing chains , timing chain inspection it's recommended by toyota at 100k , timing chain needed when chain it's stress out and produce a loud noise , if timing chain jumps more then 2 tooth it will cause internal damage to the engine , when timing chain it's off time check engine light will come on as well . a toyota engine with a timing belt, belt service it's recommended every 90k for 2004 or newer and every 60 k for 2003 or older only v6 engines timing belt are interference engines .
