timing belt question
Old Jul 15, 2012 | 08:48 PM
xharley's Avatar
Default timing belt question
I have a 2012 2.5L 4cyl. and my son has a 2008 2.4L engine. If the timing belt breaks does it damage engine? If the belt isn't changed at 100k miles, how long will it last? How much trouble are they to change?
Old Jul 15, 2012 | 09:25 PM
boricua's Avatar
a 2.5L or 2.4L engine doesn't have a timing belt , they have timing chains , timing chain inspection it's recommended by toyota at 100k , timing chain needed when chain it's stress out and produce a loud noise , if timing chain jumps more then 2 tooth it will cause internal damage to the engine , when timing chain it's off time check engine light will come on as well . a toyota engine with a timing belt, belt service it's recommended every 90k for 2004 or newer and every 60 k for 2003 or older only v6 engines timing belt are interference engines .
Old Jul 16, 2012 | 03:51 PM
xharley's Avatar
Thanks for the info.
oldad
Jan 7, 2012 07:28 PM
mathews11
Jul 4, 2008 01:18 PM
78kitty
Jun 4, 2008 02:51 PM
berries674
Mar 23, 2008 01:45 PM
amitgarg_79
Jul 21, 2007 09:35 AM
