Two 92 Camry dashboard light?
Hi! Today when I started my 92 Camry, I noticed two lights came up on my dashboard, one I know it's the battery light, the other one is orange and it looks like a car with rear lights on.
ok question #1: I checked any lights on the back of my car which all work properly, why does this dash light comes on? I know the battery light means the battery is not getting an at least 12.5v charging voltage, so it could be the alternator that's bad. so question #2: How much is the going rate to replace a alternator in an 92 Camry parts + labor in maryland? approximately. question #3: what are the other causes for the batter light to come up? Thank you so much for your help guys. |
RE: Two 92 Camry dashboard light?
i just had mytail light, battery light and brake lights go on.
my alternatorwas only putting out 11 volts. replace alternator and all lights went out. 80 amp alternator was $118 from Kragen. it's one of the easier things to do yourself as long as you don't adjust the belt too tight. |
thanks man, do you know where I can find on how to install the alternator?
