Two 92 Camry dashboard light?
Hi! Today when I started my 92 Camry, I noticed two lights came up on my dashboard, one I know it's the battery light, the other one is orange and it looks like a car with rear lights on.
ok question #1: I checked any lights on the back of my car which all work properly, why does this dash light comes on?
I know the battery light means the battery is not getting an at least 12.5v charging voltage, so it could be the alternator that's bad.
so question #2: How much is the going rate to replace a alternator in an 92 Camry parts + labor in maryland? approximately.
question #3: what are the other causes for the batter light to come up?
Thank you so much for your help guys.
i just had mytail light, battery light and brake lights go on.
my alternatorwas only putting out 11 volts.
replace alternator and all lights went out.
80 amp alternator was $118 from Kragen.
it's one of the easier things to do yourself as long as you don't adjust the belt too tight.
