What is this part?
1 Attachment(s)
Shifter was getting jammed and wouldnt shift past reverse to get into neutral or drive... after pushing on it a little, this little part fell out under the car.
can somebody please tell me what it is? it is a small round piece of what looks and feels like aluminum.. it has a crossed slot design in the top for pulling it on and off of the car around the sides it has 2 0-rings here is a crappy microsoft paint picture of it that i drew thank you in advance |
What engine (V6 or 4 cylinder) and year of car?
What is the diameter? Check the sides of the trans for what may now be a hole the size of the plug? |
Its about 1.5-2" in diameter
Based on the cover design and number of O'rings appears to be the cover for the 2nd gear coast brake assy.
Look for a hole on the side of the trans facing the radiator. Suggest you don't drive the car as the cover holds in a piston and rod plus springs which may pop out. The cover is held in by a large snap clip which must have come off. |
1 Attachment(s)
thank you all for the help!
here is a picture of an actual transmission in this pic you can see the piece in question |
The is the cover as described in the previous post.
Behind the piece is a piston, looks like a round disk the same diameter as the hole. You should see a rod end protruding from the exposed side of the piston and a snap ring holding the rod onto the piston. Make sure the piston is still installed. For the cover you will need to obtain a clip that looks much like item DHT at the link below. Might start with a Toyota dealer although this is a standard part if you can find someone that sells it. The plug installs, then is pushed in. The hole has a groove around it. The clip is compressed by pulling the two open ends together with a hand tool to reduce its diameter then inserted into the hole/groove. Once the tool releases its grip the clip expands into the groove. Rotor Clip Company - Retaining Ring Product Line |
