Why two gaskets?
Why does this come with two gaskets? It's the water pump housing to engine gasket for 97-01 camry, if that's not obvious. The mahle has only one, but these weird teeth on the inside.
https://www.rockauto.com/en/moreinfo.php?pk=9102392&cc=1375185&pt=2148 |
Engine type?
The 4 cylinder has two steel tubes that attach to the WP housing.. |
(Post 108361)
Engine type?
Yes, that one.
it goes here. At least, that's what I thought. But there doesn't seem to be room for the other? https://cimg6.ibsrv.net/gimg/www.cam...23c9bb5150.jpg |
Never used two o-rings just the flange gasket and one o-ring setup for pipes. Perhaps the rings are sold in a two pack as some application somewhere requires two rings and that is the way they were packaged.
The larger ring seals the housing to the block. Photo source: Original Mechanic.com https://4.bp.blogspot.com/-iFCkIKmcr...ee%2Bseals.jpg . |
