Why two gaskets?
Why two gaskets?
Why does this come with two gaskets? It's the water pump housing to engine gasket for 97-01 camry, if that's not obvious. The mahle has only one, but these weird teeth on the inside.
https://www.rockauto.com/en/moreinfo.php?pk=9102392&cc=1375185&pt=2148
it's for the 4 cylinder. But this isn't for the water bypass. The water bypass has one o-ring and a diamond shape gasket.
Never used two o-rings just the flange gasket and one o-ring setup for pipes. Perhaps the rings are sold in a two pack as some application somewhere requires two rings and that is the way they were packaged.
The larger ring seals the housing to the block.
Photo source: Original Mechanic.com
