Window sorta works, gets stuck down.
Hi, my 2000 camry drivers window gets stuck down. I can get it up eventually but when i push the button the window rises maybe 1-2 inches. It will not work again unless i give it a few min and then i can raise it another 1-2 inches. At first I was thinking that it was the switch however it seems to me that it may be the motor since i hear the motor kind of dying out but am not sure if its because of bad motor or switch or something else which is not giving enough power to it. Any suggestions appreciated. Thanks.
Yes you have a worn window motor. Very common for either of the front 2 to wear since they are used the most.
JJ |
