Window sorta works, gets stuck down.
Old May 12, 2009 | 12:38 AM
hayhayday's Avatar
Default Window sorta works, gets stuck down.
Hi, my 2000 camry drivers window gets stuck down. I can get it up eventually but when i push the button the window rises maybe 1-2 inches. It will not work again unless i give it a few min and then i can raise it another 1-2 inches. At first I was thinking that it was the switch however it seems to me that it may be the motor since i hear the motor kind of dying out but am not sure if its because of bad motor or switch or something else which is not giving enough power to it. Any suggestions appreciated. Thanks.
Old May 12, 2009 | 10:10 AM
Joel_CA's Avatar
Yes you have a worn window motor. Very common for either of the front 2 to wear since they are used the most.
JJ
generalpdw
Jul 28, 2015 12:57 AM
2wonder
Feb 21, 2015 09:51 PM
guapo
Jun 26, 2010 04:51 AM
StoreKeeper
Nov 27, 2007 11:32 PM
Serenityvalley
Nov 7, 2006 03:24 PM
