Fuel injector replacement
I need to replace a fuel injector on my 2011 Camry 2.5
it’s kinda difficult to see the fuel rail area clearly could someone point me to where the fuel Schrader valve is located to relieve fuel pressure from the reading I’ve done the general recommendation is gasoline to lubricate injector O-rings I’ve used this forum for three years usually I can find what I need today I could just use a little help thank |
There is no valve.
If equipped, remove the C/OPN fuse. Start engine and let it run until it quits due to lack of fuel. |
(Post 106297)
There is no valve.
Well, there are 6 fuses that are associated with multiport fuel inj
IG2, ETCS, EFI2, EFI MAIN, EFI NO 1, EFI NO 2, EFI NO 3 I am thinking either IG2 or ETCS Help? |
