Fuel injector replacement
Old Feb 14, 2022 | 12:10 PM
Oldcruizer's Avatar
Default Fuel injector replacement
I need to replace a fuel injector on my 2011 Camry 2.5
it’s kinda difficult to see the fuel rail area clearly
could someone point me to where the fuel Schrader valve is located to relieve fuel pressure
from the reading I’ve done the general recommendation is gasoline to lubricate injector O-rings
I’ve used this forum for three years usually I can find what I need
today I could just use a little help
thank
Old Feb 14, 2022 | 05:15 PM
There is no valve.
If equipped, remove the C/OPN fuse. Start engine and let it run until it quits due to lack of fuel.
Old Feb 14, 2022 | 05:28 PM
Oldcruizer's Avatar
There is no valve.
thank you sir. Sounds straight forward
Old Feb 16, 2022 | 02:20 PM
Oldcruizer's Avatar
Well, there are 6 fuses that are associated with multiport fuel inj
IG2, ETCS, EFI2, EFI MAIN, EFI NO 1, EFI NO 2, EFI NO 3
I am thinking either IG2 or ETCS
Help?
Gquinones1980
Feb 12, 2022 08:52 AM
Bruce Mclean
Nov 30, 2019 02:25 PM
Ron How
Dec 6, 2017 12:25 PM
PYRO
Sep 29, 2011 05:01 AM
thienhavodch
Dec 29, 2008 10:40 AM
