please help totally devastated
please help, I put a new battery in my 2003 camry Xle and there was appsolutly nothing wrong with the Transmission. and now it's like it's stuck below 40 And the car is my baby please help. everything I have read in the past 2 says says I can reset my ECM and it would fix it . does anyone know if This is true. I need a cheap fix
will assume its an automatic transmission
did you ever jump start the car or connect the cables to the wrong poles re-set DIY is undo the battery terminals wait a bit then reconnect the terminals start and idle the car turn off if transmission is no better you will need the engine and transmission fault codes could be the tps |
reply
Originally Posted by dirty hands
(Post 93183)
did you ever jump start the car or connect the cables to the wrong poles re-set DIY is undo the battery terminals wait a bit then reconnect the terminals start and idle the car turn off if transmission is no better you will need the engine and transmission fault codes could be the tps the car is automatic do you know how to reset this |
the engine check light should be on
i would get the fault codes read if reset doesnt work you might be up for a refurbished ECM the 2003 camry Xle toyota ECM and tranny control module comes up as a combined unit re-set is undo the battery terminals wait a bit then reconnect the terminals start and idle the car turn off |
Disconnect battery for 5 minutes.
Start engine and let warm up. Use light throttle until trans shifts properly. |
reply
(Post 93188)
I have had problems in the past with toyota whenever I change the battery, and after researching much, I found out that once the battery has been disconnected, my car has to go through about 20 drive cycles for the computer to re-adjust the oxygen to fuel mixture, which is why my car always acts up. What I do is drive for a very short distance (100 ft or so), stop, turn off the engine, re-start the engine and repeat the process for about ten drive cycles, which makes my car begin to drive like normal.
Hope this helps! |
