2016 toyota camry steering wheel knocking sound
Hello, i’ve been having problems with a knocking i have been hearing from under the steering wheel when i turn or go over bumps and i can also feel it on the gas pedal, but i do not know what the problem is and mechanics can’t figure it out as well. Does anyone know what the issue is?
camry steering sound
any help guys? anyone know what this is?
Under the steering wheel or under the cars chassis?
(Post 103171)
A knock or a rattle as in more then one knock?
Typically causes of a knocking noise over bumps are worn sway bar bushings, sway bar link or upper strut mount. Rotating the steering wheel knock can be issues with the steering wheel U-joints. Can you turn the steering wheel with the car stationary and hear a knock? |
If a ball joint is beginning to fail, you may notice a clunking noise coming from the front wheels. This helps translate the turning of the steering wheel to the direction of the tires. When a tie rod end is worn or loose, they may produce a clunking noise
My best guess would be something wrong with a tie rod end or ball joint.
i agree with the other poster , sounds maybe like a ball joint or rod. if it was something worse i think you might hear something louder and more alarming than a knocking. any updates to this situation op?
