Sights n Sounds Post your video clips here.
2016 toyota camry steering wheel knocking sound
Old Jul 29, 2020 | 06:33 PM
Sinan Seeba's Avatar
Default 2016 toyota camry steering wheel knocking sound
Hello, i’ve been having problems with a knocking i have been hearing from under the steering wheel when i turn or go over bumps and i can also feel it on the gas pedal, but i do not know what the problem is and mechanics can’t figure it out as well. Does anyone know what the issue is?
Old Jul 30, 2020 | 02:38 PM
Default camry steering sound
any help guys? anyone know what this is?
Old Jul 30, 2020 | 08:54 PM
Under the steering wheel or under the cars chassis?
Old Jul 31, 2020 | 03:42 PM
every time i turn the steering wheel, you can hear the knock or when i’m going over a bumpy road
Old Aug 1, 2020 | 12:54 AM
A knock or a rattle as in more then one knock?
Typically causes of a knocking noise over bumps are worn sway bar bushings, sway bar link or upper strut mount.
Rotating the steering wheel knock can be issues with the steering wheel U-joints.
Can you turn the steering wheel with the car stationary and hear a knock?
Old Jan 28, 2021 | 04:48 AM
LaizaM's Avatar
If a ball joint is beginning to fail, you may notice a clunking noise coming from the front wheels. This helps translate the turning of the steering wheel to the direction of the tires. When a tie rod end is worn or loose, they may produce a clunking noise
Old Jan 28, 2021 | 12:12 PM
famlii54's Avatar
My best guess would be something wrong with a tie rod end or ball joint.
Old Feb 11, 2021 | 06:20 PM
CamryPro's Avatar
i agree with the other poster , sounds maybe like a ball joint or rod. if it was something worse i think you might hear something louder and more alarming than a knocking. any updates to this situation op?
jmarcum1968
Dec 12, 2018 05:21 PM
cm11402008
Sep 16, 2008 10:28 AM
chu
Mar 17, 2008 02:28 PM
swataz
May 7, 2007 10:58 AM
lcc014
Dec 13, 2006 01:03 PM
