1993 Camry V6 Brake pulsating when coming to a stop
Hi all, whenever my Camry reaches 6 mph (10 km/h) when coming to a stop, a noise comes from the brakes which pulsates through the pedal, kind of like someone jumping on a diving board. The braking is fine when slowing down from normal driving.
The rotors have been replaced front and back with new pads and have been checked for runout. I had new struts put in last week. I have replaced the front sensors and it has made no difference at all as the sound/vibration is still there. Attached are 2 sound files to see if anybody is familar with the sound. Is this problem related to the ABS? http://rapidshare.de/files/37204365/...ulsating_1.wav http://rapidshare.de/files/37203902/...ulsating_2.wav |
RE: 1993 Camry V6 Brake pulsating when coming to a stop
one of your calipers could be hanging up. i didnt listen to your sound but that could cause you an issue check you new brake pads for unever wear. it could be your abs but, i'd go after that last it tends to be expensive.
Did they replace the squeal pads when you got new brakes? Some mechanics will leave them off
[align=left] [/align] |
diving board sound is consistent with abs noise.
