Old Aug 26, 2015, 01:07 PM
How-Tos on this Topic
Browse all: Brakes
Print Wikipost
1993 Camry V6 Brake pulsating when coming to a stop
Old Oct 19, 2006 | 10:17 AM
mixta's Avatar
Default 1993 Camry V6 Brake pulsating when coming to a stop
Hi all, whenever my Camry reaches 6 mph (10 km/h) when coming to a stop, a noise comes from the brakes which pulsates through the pedal, kind of like someone jumping on a diving board. The braking is fine when slowing down from normal driving.
The rotors have been replaced front and back with new pads and have been checked for runout. I had new struts put in last week. I have replaced the front sensors and it has made no difference at all as the sound/vibration is still there. Attached are 2 sound files to see if anybody is familar with the sound. Is this problem related to the ABS?
http://rapidshare.de/files/37204365/...ulsating_1.wav http://rapidshare.de/files/37203902/...ulsating_2.wav
Old Oct 21, 2006 | 03:43 AM
lavalleemike's Avatar
Default RE: 1993 Camry V6 Brake pulsating when coming to a stop
one of your calipers could be hanging up. i didnt listen to your sound but that could cause you an issue check you new brake pads for unever wear. it could be your abs but, i'd go after that last it tends to be expensive.
Old Apr 6, 2007 | 10:24 AM
ray92es's Avatar
Did they replace the squeal pads when you got new brakes? Some mechanics will leave them off
[align=left] [/align]
Old Apr 6, 2007 | 01:39 PM
nodrogkam's Avatar
diving board sound is consistent with abs noise.
s95136
Dec 19, 2012 09:41 PM
turtle02909
May 27, 2009 08:16 PM
camryjim
Apr 13, 2009 09:26 PM
hmthomas
Sep 8, 2007 09:30 AM
jaymik
Apr 25, 2007 07:37 PM
