wheel weights on new car?
Old 04-26-2008, 09:34 AM
deepvalue's Avatar
Default wheel weights on new car?
i just bought an 08 XLE and noticed that it has a whole bunch of wheel weights on one of the back wheels. is this normal for a brand new car? it shocked me a bit.
Old 04-26-2008, 10:57 AM
Default RE: wheel weights on new car?
All tires/rims require balancing and additional weight. If these are aluminum rims the weights are still needed but typically glued to the back. If too much weight is needed the tire could have a defect or is not be seated property. Not sure how much weight is too much; 1-2 ounces may be typical.
Old 04-27-2008, 04:33 PM
deepvalue's Avatar
thanks toyomoho.
i went out and counted the wheelweights. there are 21 of them lined up around the wheel. each one says 5 Fe which i assume is a weight and identifier that they are made of iron. they are the shape of a little rectangles.
Old 04-28-2008, 09:51 AM
sestivers's Avatar
That is completely unsatisfactory. There is either something wrong with the rim (maybe bent) or a bad tire. If the dealer won't do something about it, then you should trade that wheel out for the spare, presuming that your current spare matches your other three wheels (rim AND tire).
Old 04-28-2008, 11:48 AM
Each one is 5 grams x 21 = a total of 3.7 ounces. More then typically but not excessive. If you complain the dealer will most likely say this is just fine and not offer any assistance.
rulethestreet80
06-22-2012 10:00 AM
CAG364
06-13-2007 04:37 PM
Mur21
01-18-2006 12:03 AM
Quick Reply: wheel weights on new car?
