2004 Camry 230,00 Miles USA built. Rotors and pads
Hello all, I plan to keep this car for as long as I can. Still runs good. I usually shop Rockauto and am seeing some different size rotors and am looking for a mid grade rotor and better pads. Any advice? 2004 Camry LE 2.4L Thank you Very much!!
You need the correct outside diameter rotor. It appears the Camry SE version has a larger rotor then LE, thus get one listed for LE. The thickness is what you get and any of the rotors should be OK.
As to brands everyone has their own opinion. Biased toward Brembo so something like BREMBO 09A38611 for front and BREMBO 08A10811 for rear. For pads try AKEBONO. If want to avoid issues of brake squeal get Toyota brand OEM. |
