2004 Camry 230,00 Miles USA built. Rotors and pads
Old May 20, 2020 | 12:53 PM
cherrmj's Avatar
Default 2004 Camry 230,00 Miles USA built. Rotors and pads
Hello all, I plan to keep this car for as long as I can. Still runs good. I usually shop Rockauto and am seeing some different size rotors and am looking for a mid grade rotor and better pads. Any advice? 2004 Camry LE 2.4L Thank you Very much!!
Old May 20, 2020 | 08:35 PM
You need the correct outside diameter rotor. It appears the Camry SE version has a larger rotor then LE, thus get one listed for LE. The thickness is what you get and any of the rotors should be OK.
As to brands everyone has their own opinion. Biased toward Brembo so something like BREMBO 09A38611 for front and BREMBO 08A10811 for rear. For pads try AKEBONO. If want to avoid issues of brake squeal get Toyota brand OEM.
Jordan31
Jul 30, 2019 02:24 PM
Swift101
Jun 11, 2013 12:44 PM
brianjrealtor
Mar 9, 2010 07:29 PM
lacruiser
Feb 18, 2009 11:53 PM
ted920
Aug 14, 2008 08:52 PM
