92 camry clunking sound
I bought the car about a month ago with 209000 miles. The PO said the timing belt was changed at about 140000. I had the timing belt and water pump and also put in a new T/stat. The car runs great except for the clunking sound when I go over rought road. The mechanic said the struts were good. Do I have to replace the sway bar bushing or the sway bar link.
RE: 92 camry clunking sound
hard to say where the noise is coming from, but the most comman problem would be the strut, strut support and sway bar bushings.
i have a clunking sound on my '99 - comming from the front left strut and i was told that itsfrom my strutmounts.
Today my '98 just started a clunking sound in my front left as well going over bumps over the highway. Does not sound good. It has always had a creaking type of noise since I've owned it that I figured were the strut mounts which are notorious for that. I'll look at it a little closer tonight after work.
well i figured mine out. my brake caliper had come lose and was clunking from the extra movement. i did both my camry and sienna brakes in december and both have loosened up over time so i must have done something wrong.
I'm a little late to this post, but my '99 also has a clunking sound when I go over any sort of ruff road, except mine is from the rear, I believe the driver side. Does anyone have any idea what it could be? I plan on replacing the rear struts here soon, I'll have to post results if it changed anything...
Thanks for any help you can give. -Kevin |
