92 camry clunking sound
Old Feb 18, 2007 | 08:51 PM
bigdog's Avatar
Default 92 camry clunking sound
I bought the car about a month ago with 209000 miles. The PO said the timing belt was changed at about 140000. I had the timing belt and water pump and also put in a new T/stat. The car runs great except for the clunking sound when I go over rought road. The mechanic said the struts were good. Do I have to replace the sway bar bushing or the sway bar link.
Old Mar 12, 2007 | 04:42 AM
toyoboy's Avatar
Default RE: 92 camry clunking sound
hard to say where the noise is coming from, but the most comman problem would be the strut, strut support and sway bar bushings.
Old Mar 12, 2007 | 05:10 AM
OnE_To_HatE's Avatar
i have a clunking sound on my '99 - comming from the front left strut and i was told that itsfrom my strutmounts.
Old Mar 12, 2007 | 06:44 PM
kwtrading's Avatar
Today my '98 just started a clunking sound in my front left as well going over bumps over the highway. Does not sound good. It has always had a creaking type of noise since I've owned it that I figured were the strut mounts which are notorious for that. I'll look at it a little closer tonight after work.
Old Mar 12, 2007 | 11:52 PM
kwtrading's Avatar
well i figured mine out. my brake caliper had come lose and was clunking from the extra movement. i did both my camry and sienna brakes in december and both have loosened up over time so i must have done something wrong.
Old Jun 27, 2012 | 09:18 PM
km670909's Avatar
I'm a little late to this post, but my '99 also has a clunking sound when I go over any sort of ruff road, except mine is from the rear, I believe the driver side. Does anyone have any idea what it could be? I plan on replacing the rear struts here soon, I'll have to post results if it changed anything...
Thanks for any help you can give.
-Kevin
standfast
Nov 20, 2011 07:39 PM
84BATA
Mar 18, 2011 03:21 AM
Yobearcat
Mar 28, 2010 02:59 AM
camryseeker
Nov 29, 2009 04:34 PM
