Bad struts I think..
Okay, every time I go over even the slightest bump, my rear end has a knocking sound. I consulted a couple people who, with the same issue, have diagnosed it to be... "they're shot." Now this car looks completely stock right down to the factory hub caps. I was debating on giving the thing a small drop, but idk if I'll have the room for that kinda work. Should I just replace the struts and save the drop for later? or just ignore it because I wont hear a damn thing after the kickers are put in?
RE: Bad struts I think..
Lots of things can cause rear end knock when going over bumps. A few common ones are stabilzer bar bushings and end links, upper shock mounts, worn suspension bushings.
Suggest changing the stabilizer bar bushings first as this is a quick and cheap fix. Suppose it is possible the strut itself may be making noise but typically it is these other items. |
THANK YOU! I will take a look into all that I'd prefer the quick and cheap fix. ANd thanks I think you're the first to reply out of my 4 or 5 posts. :eek:
