Bad struts I think..
Old Feb 12, 2008 | 09:02 AM
94camguy's Avatar
Default Bad struts I think..
Okay, every time I go over even the slightest bump, my rear end has a knocking sound. I consulted a couple people who, with the same issue, have diagnosed it to be... "they're shot." Now this car looks completely stock right down to the factory hub caps. I was debating on giving the thing a small drop, but idk if I'll have the room for that kinda work. Should I just replace the struts and save the drop for later? or just ignore it because I wont hear a damn thing after the kickers are put in?
Old Feb 12, 2008 | 01:11 PM
Default RE: Bad struts I think..
Lots of things can cause rear end knock when going over bumps. A few common ones are stabilzer bar bushings and end links, upper shock mounts, worn suspension bushings.
Suggest changing the stabilizer bar bushings first as this is a quick and cheap fix.
Suppose it is possible the strut itself may be making noise but typically it is these other items.
Old Feb 13, 2008 | 12:00 PM
94camguy's Avatar
THANK YOU! I will take a look into all that I'd prefer the quick and cheap fix. ANd thanks I think you're the first to reply out of my 4 or 5 posts.
1995YotaCamry
Oct 17, 2009 05:38 PM
speedfreak87
Dec 29, 2008 10:19 AM
NothingSound
Mar 6, 2008 07:42 PM
vin888
Jul 24, 2007 11:26 PM
importtuned1
Jun 7, 2007 03:32 PM
