WIDEST TIERS - ADVICE PLZ
Hi ... I wanna know what is the widest tiers I can fit for my stock rims which the original size came on them was 195-70-R14
rims widthe is 7 inchs Thanx |
RE: WIDEST TIERS - ADVICE PLZ
not quite sure u can go wider than that.
205 is the next in width. |
you should be able to fit 205...but be carefull some tire brandsare a little wider than others..i had 205 goodyear and i replaced then with 205 continental and the continental rubbed the rear shock so i had to go a size down....
Well according to the brand that I wanna fix (simitomo) the chart shows the following >>
Tire Size Load Index Design Rim Width (inch) Rim Range (inch) Single Max I.P. (psi) Single Max Load (lbs) Overall Diameter (inch) Section Width (inch) Tread Depth (X/32") Static Loaded Radius (inch) Tire Weight (lbs) 205/70R14 95H 6.00 5.0 - 7.0 51 1,521 25.4 8.2 10.0 11.4 21.2 OR 205/60R14 89H 6.00 5.5 - 7.5 51 1,279 23.8 8.0 10.0 10.7 19.2 http://www.sumitomotire.com/theline/...c=per&id=5 so I guess am going foe the 2nd type as it to be 205-60-R14 the reason I've chosen Simitomo is that it has an amazing road gripp (Traction) as I've used them on my 1990 Mustang& it stopped drifting !! even I couldn't do a complete donuts !!! also I've used them on 1986 Caprice 255-65-R15 & they performed nearly as street race tiers also on many other cars. Thanx for the advice |
60 vs 70 will give you a firmer ride with better handling, but your speedometer will be off by 1 or 2 kph
simitomo is good, but i prefer yokohama or bridgestone. |
thanx for the advice :)
you can put any tiresyou like...but any time you alter the oem spec..like your tire size.....there will be a chance that something won't fit...i would advice you to purchase locally and not on the internet...in case something goes wrong..good luck
yeah ur right am going for my local dealer here in Bahrain ... & they usaly give a 1 year warrenty on manuf. def.
thanx again :) |
