Will 20" Wheels fit 2013 Camry?
Hi all, I have a 2013 Camry and came across a buddy that is selling his almost new wheels. He said it's a universal 5 lug pattern and should fit but I want to make sure before buying. The wheels are MSR 42 - 20" black rims. I'll attach a picture of the lug pattern. If anyone has any knowledge on the Camry lug patterns it would be much appreciated. Thanks.https://cimg6.ibsrv.net/gimg/www.cam...55b6d9712d.jpg5 lug bolt pattern fit 2013 Camry?
Need to measure the bolt pattern, find a part number on the rim or test fit the rim to the car.
These rims have two different bolt patterns, however there are more then two used by car makers. Camry specs are bolt pattern 5 x 114.3. Offset: 40mm. Center Bore: 60.1mm |
Thanks
Thank you for your response. I found the same wheels online but not sure if the specs online are the same as the wheels my buddy has. I know he had them on a Honda. I've attached a pic of the specs I found online.https://cimg5.ibsrv.net/gimg/www.cam...14bf9d8d1f.png
Per the link below, yes they will fit.
Camry uses the 5 x 114.3 bolt pattern. http://www.caliwheels.com/msr-wheels...els-w-1995.htm Click on 5 LUG MACHINED WITH BLACK TRIM in available finishes.. Suggest calling the business to confirm. |
