2000 Camry wiper relay
Does anybody know if the wiper relay of a 2000 Camry XLE is a separate box or if the relay is located with the wiper switch...:p
Relays are in the combo wiper and washer unit that is part of the control arm on the steering column.
The switch to park the wiper is in the motor. |
Relays are in the combo wiper and washer unit that is part of the control arm on the steering column. The switch to park the wiper is in the motor. |
So, if the intermittent function and the park function both fail at the same time, do the switch AND the motor both have to be replaced ?
Does the wiper work Ok in the low and high speed positions?
Yes, Joey, the wiper works in both low and high setting. When the switch is set to the intermittent setting, the wipers work the same as if the switch is in the low-speed setting.
