2000 Camry wiper relay
Old Apr 30, 2011 | 01:32 PM
foondoon's Avatar
Question 2000 Camry wiper relay
Does anybody know if the wiper relay of a 2000 Camry XLE is a separate box or if the relay is located with the wiper switch...
Old Apr 30, 2011 | 07:20 PM
Relays are in the combo wiper and washer unit that is part of the control arm on the steering column.
The switch to park the wiper is in the motor.
Old May 3, 2011 | 09:28 PM
full house's Avatar
by the way it sound, its not separate... just a combo right?
Old May 4, 2011 | 06:44 PM
foondoon's Avatar
So, if the intermittent function and the park function both fail at the same time, do the switch AND the motor both have to be replaced ?
Old May 4, 2011 | 09:56 PM
Does the wiper work Ok in the low and high speed positions?
Old May 10, 2011 | 09:33 PM
foondoon's Avatar
Yes, Joey, the wiper works in both low and high setting. When the switch is set to the intermittent setting, the wipers work the same as if the switch is in the low-speed setting.
capndavy
Jan 25, 2020 11:09 PM
foondoon
May 8, 2011 02:52 PM
runner5113
Feb 10, 2011 10:43 PM
*The Best*
Jun 24, 2010 09:29 AM
mervinjules
Jun 29, 2009 01:15 PM
