2020 le abs
Is the front left ABS supposed to look like this? Having ABS warning issues and checking before I replace. Code C1331: open circuit in left front speed sensor circuit.
https://cimg4.ibsrv.net/gimg/www.cam...0f63ffd48.jpeg |
(Post 110152)
https://cimg6.ibsrv.net/gimg/www.cam...5d3e6620f.jpeg https://cimg7.ibsrv.net/gimg/www.cam...fc135f51b.jpeg https://cimg8.ibsrv.net/gimg/www.cam...6f87e900d.jpeg https://cimg9.ibsrv.net/gimg/www.cam...2ba9f8e99.jpeg |
Does the car have collision alert radar?
C1331 is sensor, sensor rotor, wiring, ECU. C1A4B Brake booster with master cylinder (skid control ECU) detects a malfunction in the stop light control relay circuit for 1 second while the dynamic cruise control is operating. Stop light control relay Stop light control relay circuit Brake booster with master cylinder (Skid control ECU) C1A50 When signal malfunction from brake booster with master cylinder (skid control ECU) continues for 1 second while dynamic radar cruise control is operating. Electronically controlled brake system Driving support ECU Suspect C1A4B is causing C1A50. |
is this sensor safe to use there is a component in this product that the state of California knows to cause cancer and reproductive harm. says the website.
