2020 le abs
Old Oct 29, 2023 | 04:53 PM
LaloHawaii's Avatar
Default 2020 le abs
Is the front left ABS supposed to look like this? Having ABS warning issues and checking before I replace. Code C1331: open circuit in left front speed sensor circuit.
Old Oct 29, 2023 | 10:23 PM
Old Nov 1, 2023 | 02:30 AM
LaloHawaii's Avatar
Thank you, awaiting new part. Hopefully this is the end-all for the ABS issue. Would that bad wheel speed sensor be the culprit for these readings also?
Old Nov 1, 2023 | 12:36 PM
Does the car have collision alert radar?
C1331 is sensor, sensor rotor, wiring, ECU.
C1A4B
Brake booster with master cylinder (skid control ECU) detects a malfunction in the stop light control relay circuit for 1 second while the dynamic cruise control is
operating.
Stop light control relay
Stop light control relay circuit
Brake booster with master cylinder (Skid control ECU)
C1A50 When signal malfunction from brake booster with master cylinder (skid control ECU) continues for 1 second while dynamic radar cruise control is operating.
Electronically controlled brake system
Driving support ECU
Suspect C1A4B is causing C1A50.
Old Feb 21, 2024 | 01:01 AM
davideidson's Avatar
is this sensor safe to use there is a component in this product that the state of California knows to cause cancer and reproductive harm. says the website.
DanielAndrew
Mar 30, 2022 02:38 AM
granadaCoder
Jul 29, 2008 12:43 PM
dpjarvis25
Jun 6, 2008 10:16 PM
hmthomas
Sep 8, 2007 09:30 AM
92CAMRY
Jul 14, 2006 05:52 PM
