Just purchased a 2010 Camry SE V6
Hello. Just purchased a 2010 Camry SE V6. Has 206,000kms. I don't have a full service history of car and was wondering what you guys would recommend for service. I am not sure if any of the recommended fluid changes have been done. Is there one in particular I should do first while some others wait? Any help would be appreciated. I am new to Owning a Toyota.
Thank you! |
Look into changing the trans fluid.
Thanks Joey, I felt that was probably most important.
I would also look into coolant change, spark plugs, air filter, cabin filter, and brake fluid if it is dark brown.
If it runs well, just basic maintenance should be all it needs. I would also second the transmission fluid but I would do a drain and fill, as opposed to a flush. That kind of mileage you don't want to stir things up too much. |
Thank you very much for info. Yes definitely will just change the fluid and not flush. Appreciate your info.
