Just purchased a 2010 Camry SE V6
Old Nov 24, 2022 | 10:50 AM
LucioD's Avatar
Default Just purchased a 2010 Camry SE V6
Hello. Just purchased a 2010 Camry SE V6. Has 206,000kms. I don't have a full service history of car and was wondering what you guys would recommend for service. I am not sure if any of the recommended fluid changes have been done. Is there one in particular I should do first while some others wait? Any help would be appreciated. I am new to Owning a Toyota.
Thank you!
Old Nov 24, 2022 | 11:42 AM
Look into changing the trans fluid.
Old Nov 24, 2022 | 11:58 AM
LucioD's Avatar
Thanks Joey, I felt that was probably most important.
Old Nov 24, 2022 | 11:55 PM
I would also look into coolant change, spark plugs, air filter, cabin filter, and brake fluid if it is dark brown.
If it runs well, just basic maintenance should be all it needs.
I would also second the transmission fluid but I would do a drain and fill, as opposed to a flush. That kind of mileage you don't want to stir things up too much.
Old Nov 25, 2022 | 07:02 AM
LucioD's Avatar
Thank you very much for info. Yes definitely will just change the fluid and not flush. Appreciate your info.
Old Jun 4, 2024 | 10:34 AM
wintersearch's Avatar
I second checking the cabin air filter. Its the most overlooked yet the esiest to change. I have seen used cars from the dealer claim to have changed the filters only to have never actually changed them for years yet charged the customer and logged the work.
10camrySE
Oct 15, 2012 01:37 PM
sonofnate10
Jul 2, 2012 04:27 PM
toslow1
Dec 29, 2009 10:12 AM
aimee
Feb 10, 2009 10:04 PM
aimee
Jan 24, 2009 04:33 PM
