engine cleaning
engine cleaning
I was wondering if someone could help me. My engine is dirty and I wana give it a nice cleaning only I don't know how... I know you don't wana get the alternator wet and stuff but other than that I'm confused any help would be great
RE: engine cleaning
use the brake cleaner, its a green bottle. even though it said for brake kits, it also work for cleaning engine and things around it. spray it on top of the engine and around the area cuz your alternater is on the bottom so just try to keep the spray away from it
RE: engine cleaning
I've seen some engine cleaning kits at pepboys. I also had afriend told me to put a plastic bag over the alternator so it doesn't get anything in it at all. I have an oil leak so my engine has a bunch of gunk all up on it
RE: engine cleaning
No. The cleaner and wash water typically get into the wire connectors. Just had this happen on a Honda after being very careful, needed to pull the connectors and spray with WD-40 to start the engine.
