Old 08-25-2015, 05:25 PM
How-Tos on this Topic
Browse all: Exterior Guides
Print Wikipost
Water leaking through sunroof.
Old 10-02-2012, 10:33 AM
allfy16's Avatar
Default Water leaking through sunroof.
I have a 2001 Camry LE and my sunroof will not open, it will only vent. I don't really care about that but I do care that the sun roof will not completely seal shut. When it rains the water will come in through the sunroof and drain down the sides of the car (behind the wall) and dump out on the floor. The water doesn't come through the ceiling, there's no water spots, but it runs down the side wall somehow and ends up soaking the driver and passenger side floor. Any idea how I can fix this? Thanks
Old 10-03-2012, 10:11 AM
The sunroof assembly has a drain tube at each corner of the frame. Each tube runs down a chassis pillar to drain out onto the ground.
Check for plugged or damaged tubes.
Old 03-19-2019, 06:25 AM
missouriupser's Avatar
I figure your sunroof drains are stopped up and need cleaned out. But first you must get sunroof open to do that. I have a 2010 Camry and have to clean them occasionally with soapy water and air pressure. My sunroof drains are in the front two corners of the sunroof.
Old 04-18-2022, 06:05 PM
murfalini's Avatar
Would the water drain into the truck area if the sunroof drain Lorne’s are plugged?
D Lawson
03-19-2019 06:27 AM
Sox_Fan_13
08-21-2015 12:58 AM
brianjrealtor
06-27-2011 01:42 AM
brianjrealtor
10-19-2010 11:21 AM
E_S
08-16-2009 11:21 PM
Quick Reply: Water leaking through sunroof.
