Sign in using an external account
| Register | Photos | FAQ | Members | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendors | TSB & Recalls |
| View Poll Results: Is the quality of your Camry what was expected at time of purchase? | |||
| Better than expected |
1 | 33.33% |
| As expected |
1 | 33.33% |
| Poorer than expected |
1 | 33.33% |
| Voters: 3. You may not vote on this poll | |||
LinkBack | Thread Tools | Search this Thread |
hi,I have the same problem and I went to the dealer they told me that I needed a new ecu which was going to cost me 590.80 plus an hour labor.I thought that this
should not have gone bad on a 2006 camry with 66,000 miles.I called toyota for assistance and they agreed to pay half of the repair.(reinbursment)I'm not happy about that.I have lost my dependability for toyota.Does anyone else feel this way? |
I sure feel that Toyota is loosing it grip on having a reputation as being trouble free.
I have had four older Toyotas and all I did was gas and oil. One thing to point out though is Toyota isn't the lone ranger. I was going to get a BMW until I read the review about them. Their transmissions are so bad about reverse going out there is actually a "NO reverse club!". Of coarse not all have this problem, just as not all Toyotas have their problems. The service on about all the cars are nightmarish now. It's sad they don't step up to the plate and treat their customers like they want them to buy their product again.
Hi,
My 2006 Camry keyless remotes stopped working a couple of months ago. I actually have two but neither of them worked any more. I found this posting this morning, tried the Add procedure and it worked. However, a few hours later, it stopped working again. So, I decided to program it again. During the process, somewhere in the step 9 or 10, I accidentally open the car door. Because of that, I thought I'd do it again from the 1st step. Unfortunately, the lock no longer cycle, it was quiet within step 10. I tried the "Rewrite" mode, but nothing happened, the car lock did not cycle. I'm reluctant to try Confirmation or Prohibition mode, been afraid that something worse may happen. Please advice ... Thanks very much in advance. |
2006 Camry. In the past few months I've reprogrammed my keyless remote so many times that I know the procedure by memory. I located the wireless receiver in the passenger side rear door panel under the airbag. It was easy. One 10mm bolt and the panel has pop off rivets. Not really sure how to test it other than with a ohm meter and it appeared to be ok. I reprogrammed it and an hour later it didn't work. I got so damn mad I smacked the exterior of the passenger side panel and locks then worked. Now I'm wondering if there is a short somewhere.
Does anyone know if the keyless remote unit a separate unit from the ECU which is behind the glove compartment? |
Here is the best method to test your door receiver. Unplug the receiver, get circuit board out of housing (shell), plug that board back to where it was. Get hair dryer from your wife or still it from your girlfriend, heat up the board from components side (board needs to get really hot) while heating up the board press lock or unlock button on remote control. If you get it work then it’s temporary fix so you know the root cause. Replace door receiver. Get this door receiver from junk yard. Camry 2002 through 2006 uses same part 89741-AA020. When you call junk yard to see if they have Camry 2002-2006 never give them part number, they will charge you more for it. Even second grade student can replace this part easily. I got mine for $35 for 2006 Camry. Good luck. Do not forget to reprogram your keyless remote.
| Tags |
| 06, 2006, camry, control, door, keyless, location, lock, problems, receiver, reciever, reciver, remote, replace, toyota |
