How to download check engine codes for a '95 V6?
Old 09-15-2007, 10:52 AM
rx7fb's Avatar
Default How to download check engine codes for a '95 V6?
My 1995 LE V6just lit it's CEL. I sent for the "tool" that would get the code from the ECU memory by Equus. It plugs in to the Diagnostics but no flashes occur with the light. Additionally, I pulled the ECU fuse to reset the CEL to confirm a fault, but the CEL remains on without starting the engine (apparently never resetting). What do you think?
Old 09-21-2007, 11:47 PM
toyoboy's Avatar
Default RE: How to download check engine codes for a '95 V6?
im pretty sure you need a scan tool the connects to the dia. connecter 3 located behind the drives coin compartment next to the fuse box...
Old 09-26-2007, 07:57 AM
geoff5093's Avatar
The CEL will always be on when the car is in the "ON" position without the car started. The car has to be running to see if you have a CEL or not. Any auto store can pick up the code because your ECU is OBDII compliant, although they may tell you it's not because it's now a '96+ car, but dont believe it. The 94+ V6 models are OBDII compliant.
vin888
11-13-2019 06:19 PM
wolfdog2
11-28-2012 09:46 PM
PredatoryTrep
05-23-2010 08:14 PM
nj55
10-15-2009 07:16 AM
Quick Reply: How to download check engine codes for a '95 V6?
