Coolant Temp Sensor - 91 Camry Le V6
Old 10-30-2009, 01:07 PM
gbskunk's Avatar
Default Coolant Temp Sensor - 91 Camry Le V6
I recently bought a 91 Camry LE V6 with 150,000 miles for what I think was a pretty good deal ....$500. Only some minor scratches to the body, so after redoing all four disc brakes and giving it a tune-up myself, I have been driving it for the past two weeks and for the most part was seeing why these cars are legendary for their quality and reliability
This past weekend I had to fix a problem with the cooling system. The heater hose from the Coolant Temp Sensor
(CTS) developed a small crack and was leaking anti-freeze. Rather than take a chance I replaced all of the heater hoses which was a job in itself. I swear, it's a good thing Toyota's have such a good reputation because they sure are pain to work on when it comes to fixing anything!
Anyhow, I noticed the CTS had, what I'm assuming are, vacuum lines broken on both of the sensors (see attached - B). Although I didn't notice any hissing when the engine is running, I decided to plug the two hoses just to be safe. Keep in mind too, I'm pretty sure they were broken previously but just never noticed it.
Can anyone tell me what exactly the CTS does, and what the significance is of those broken vacuum lines?
Thanks in advance.
rtuite
12-29-2014 12:14 PM
Debunker
12-05-2013 03:02 PM
pewterpower
05-02-2009 10:22 PM
vin888
03-06-2008 08:39 PM
saxman
10-03-2007 11:06 PM
Quick Reply: Coolant Temp Sensor - 91 Camry Le V6
