Sponsored by:
Sponsored by:
seatbelt alarm
Old 11-29-2006, 12:01 AM
brksellt's Avatar
Default seatbelt alarm
I have a 2006 Camry LE 4cyl. please tell me how to cut off the seatbelt alarm.
Old 11-29-2006, 08:54 PM
greenfire's Avatar
Default RE: seatbelt alarm
If you are wearing your seatbelt, there should be no need to disconnect the alarm.
Old 11-29-2006, 10:13 PM
lavalleemike's Avatar
there is no turn off put on your seat belt or if you want to risk your life go to the junk yard and get the metal peice that connects the seat belt and put it in there so the car thinks you belt is on
Old 05-11-2008, 08:06 AM
deepvalue's Avatar
I have an 08 XLE. When I place my briefcase on the passenger seat, the car thinks there is a passenger there.A short time after I roll down the road I have to listen to the passenger seatbelt alarm go off. It's very annoying. Is there a way to trick the car? I'm not sure if it's the weight on the seat or if it's the opening of the passenger door to put the briefcase on the seat that triggers the alarm.
Old 05-12-2008, 09:20 AM
acidmeld's Avatar
Only the dealerhas the tooldo what you want but 99% (including myself)wont touch it because ofaccident liability.
Old 05-12-2008, 09:58 AM
sestivers's Avatar
ORIGINAL: deepvalue
Put your briefcase on the passenger floor, or in the back seat on the floor. It's safer there anyway.
Old 05-12-2008, 08:05 PM
deepvalue's Avatar
Good tips, thanks.
Btw, I checked to see if placing my briefcase on the passenger seat from the driver's side without opening the passenger door would avoid the problem. However, that didn't work.It appears to be the weight on the seat that triggers the passenger seat belt alarm.
Old 05-12-2008, 08:42 PM
94camguy's Avatar
Yes, on most newer vehicles there is a sensor embedded within the cushion of the seat. Even a gallon of milk will set it off (my 05 gmc yukon is like that) I know that (in the yukon at least) the sensor also arms the passenger air bags. They'll only deploy in an accident where the computer "feels" weight in the passenger seat.
I knew someone who got thrown through the windshield on the highway because they werent belted in an accident. He broke his face (eye socket and forehead) 3 ribs and collapsed his lung, and I believe his arm was broken in 3 places. I'd suggest just using the seatbelt.
ct63366
10-02-2008 07:34 PM
ct63366
10-02-2008 10:58 AM
dwm1225
08-21-2008 08:24 PM
wildmonk
07-10-2007 10:57 PM
unsub
02-07-2007 07:35 PM
Quick Reply: seatbelt alarm
